Harmony sends different signals with same button!?
Verfasst: 30. Juli 2007 08:18
Hi ppl!
I need your help
I have this hardware:
- Logitech Harmony 555 programed as Microsoft Remote Control model:1039
- Igor Cesko's IR-USB dongle builded by this scheme on his page http://www.cesko.host.sk/IgorPlugUSB/Ig ... R)_eng.htm
Problems goes like this:
I'm using Girder 5 beta. In plugins i have loaded an IgorUSB plugin, downloaded from his website. I've left setup of that plugin on "default"
Then I go in Girder to "add remote" option, and on press on any of my Harmony's buttons, setup goes to map the keys (so far so good)
BUT, then a problem: while on mapping, any pressed key on remote sends a whole bunch of signal so 3 or more buttons are mapped by one click!
It looks something like this:
If i press button "Play" it sends a burst of commands, like "signal_1, signal_3, signal_x, signal_y", always more that one command per click
Then, like if I press a button "ok" it sends "signal_4, signal_x, signal_5, signal_6"
As you can see, a remote sends a same command on two different buttons (a signal_x).
My questions are
1. how to restrict remote to send only one sort of signal/command per key press?
2. how to restrict remote to send only one signal/command per key press?
a desired result would be:
If i press button "Play" it sends a command like "signal_x, stop"
Then, like if I press a button "ok" it sends "signal_4, stop"
Different single command per keypress...
Thanks in advance!
I need your help
My questions are
Thanks in advance!
