Neues Firmware-Update Logitech 1000
Info aus dem offiziellen Logitech-Forum:
Following a recent release of the Harmony 1000 firmware, a limited number of customers have reported that their Harmony 1000 exhibits one or more of the following symptoms:
-Remote Freezing
-Invalid Region Error when upgrading firmware
-Remote stops sending Infrared temporarily
Logitech is pleased to announce that we have identified the root cause and developed a new version of firmware for the Harmony 1000 which addresses this issue. This new version of firmware is now available for download to your remote.
To take advantage of this fix, using the Harmony Remote control software, login to your Harmony account and update your remote. Please follow the instructions below to update your Harmony Remote:
1. Ensure that the Logitech Harmony Remote Software is installed on your computer.
2. Connect your remote control to your computer using the USB cable provided.
3. Login to your Harmony account.
4. Click on the yellow Update Remote button located in the top right corner of the Activities Home Page window.
5. Follow the update wizard instructions to upgrade the remote firmware and configuration.
Na, da kann man ja nur hoffen, dass
a) die o.a. Probleme damit wirklich beseitigt sind
b) keine neuen Probleme auftauchen
bondskin
1. Harmony: 1000
1. Harmony: 1000
Beitrag von bondskin »
sieht gut aus bei mir, zum ersten Mal ohne Probleme die Firmware und die Aktualisierung übertragen.
Keine Fehler bisher festzustellen
